Amopower
If you need to install a T fitting on a straight gas pipe that is connected to elbows on either end, how do you remove that straight pipe? I'm guessing that turning the pipe counterclockwise will loosen one end, but at the same time, the other end will get tighter and tighter, and probably will stop turning at one point. Is there a trick to do this?
An example of this would be at the gas meter itself, where you have a straight piece about 9" that is connected on either end to a 90° elbow.
