Results 1 to 5 of 5
Thread: ? Application of T plus 2 Rectorseal
Hybrid View
    DIY Junior Member handygirl911's Avatar
    May 2006
    Irving, Texas
    Default ? Application of T plus 2 Rectorseal
    I forgot to get PVC glue while at Home Depot. I have this Rectorseal T Plus 2Teflon Thread Sealant. What I am trying to do is attach a PVC cap onto a PVC pipe and a threaded adapter on the other end. I need this to have a good seal because I will be pouring Muratic Acid in the pipe to soak limed up stainless steel. My question is concerning the sealant. Is this a strong enough adhesive to seal the pipe fittings? Thank you for your advice.
    Yakima WA
    I have serious doubts for this reason. So-called PVC glue is not glue or adhesive. It is a solvent that liquifies the surface of the PVC pipe and fitting for a few seconds while the joint is being assembled. It actually welds the joint together, much like metal welding where the heat liquifies the metal of both pieces being welded and allows the metal to flow together. Virtually any hardware store will have PVC solvent, and I suggest you get the proper material. Note: ABS is joined the same way except the chemical is different.
    Feb 2005
    Talking dont be stupid
    Dont be foolish........
    go back to the store and shell out
    3 bucks for the right pvc glue....
    you are pouring muratic acid into something you are
    attempting to "half ass" together right?????
    what do you think might happen????
    Plumber Cass's Avatar
    Nov 2005
    If the chamber you have made is air tight and you pour the acid into it and seal it it could explode from pressure build up. Why don't you get a plastic open vessel and do this outside. Thread sealant will not bond, glue, or solvent weld PVC pipe.
    Default sealant
    I guess I misread your posting. I thought you wanted to use the sealant to connect a cap to the threaded connection, not "glue" the pipe together. There is no way it would make a leakproof joint, and since it is also a lubricant, the pipes would probably come apart even easier than if you had just pushsed them together without anything on them.
