jlohrenz
- Messages
- 45
- Reaction score
- 0
- Points
- 0
I've only done a little bit of soldering, but this is the first time it is something that will eventually be covered up.
We are remodeling our master bath and as such I'm putting in two new faucets (Bath and Shower). Everything is soldered up. I only needed to 'manually' solder two joints. The rest were the neat little fittings that have solder in them already.
I slowly turned the water on and ran the faucets turning them on and off several times. No leaks so far.
It'll be about a week before the walls are covered up. Am I correct in assuming that if a leak is to spring up it'll happen within the next week?
TIA!
Jason
TIA!
Jason
