Results 1 to 15 of 15
Thread: bathtub ceiling faucet
    DIY Junior Member
    Aug 2006
    san diego
    Default bathtub ceiling faucet
    any suggestions greatly appreciated
    i am remodeling my master bathroom and want to put in a ceiling faucet over the bath tub. i've checked and kohler makes such a fixture. however it's price at $287.78 is a deterrent. do i need to buy this item if i want a seamless stream of water that resembles a clear glass rod? what options are there? just looking to save money. help please?!!
    ps:item in question is kohler k-922-cp laminar
    Not to be a wiseguy, but you mean shower head, not faucet, right?
    (important note: I'm not a pro)
    DIY Junior Member
    Aug 2006
    san diego
    i really do mean faucet. it's a tub only water supply. my shower will be separate and free standing. instead of the water coming from a faucet from the wall, it'll be from the ceiling.
    Nov 2005
    Central Florida
    God, is that cool! I hope my wife never sees that thing. It'd be worth every penny of $267 (lowest price I found), if I were still single .
    Looks like something out of Star Trek.
    Scotty, beam me aboard!!
    I would think that dropping that stream through 8' of air would cool it off more than you want so you'd be paying for more energy with your style. If you are worried about the price of the thing, I'd think twice.
    DIY Junior Member
    Aug 2006
    san diego
    Default ceiling faucet
    thank you for your inputs.
    as for the air cooling off the water. i'm also installing a new air spa tub with a heater. i know it's an indulgence but my wife and i don't take baths that often so it won't be too expensive as far as energy goes.
    my point for this post is this: can i just run water out of a 1.5 inch pipe and have glass rod like stream of h2o?
    Quote Originally Posted by vu
    My guess is no. The almost $300 faucet probably focuses the water in such a way as to make the nice "glass rod" appearance.
    The other way would probably just look like water coming out of a pipe.
    Nov 2005
    Central Florida
    That's my guess too. I'll bet there's some very fancy fluid dynamics involved in the design of this thing.
    Quote Originally Posted by Verdeboy
    Great description!
    DIY Senior Member Pewterpower's Avatar
    Jun 2006
    Tampa
    This is so cool!!
    I know when I'm taking a bath, I like to add hot water every now and then. That would be a royal pain with this setup. Unless, of course, there's some sort of remote control. Or perhaps it's voice activated or thought activated. Just don't let that beam of hot water hit you. It'll hurt!!
    Jun 2006
    Tampa
    Looking closely at that pic, I see some interesting things:
    Not much privacy
    Where are the H&C for the tub?
    The shower looks very cool, too.
    As does the sink, with the faucets in the wall.
    I wish my hot neighbor had a bathroom like that...
    THe Kohler part you see in the picture is not a faucet only the remote filler. TO install this, you use a faucet which supports a remote filler. These aren't all that common with the cheap junk you buy at the local big box stores (i.e Price Fister, Delta etc). But most of the nicer stuff VOLA, high end Kohler have these faucets.
    BTW this filler uses laminar techniques to generate the fine stream. Really neat fixture.
    Nov 2005
    Default look at the square tile shower heads. Also from Kohler
    even newer product. Square array of holes. Angled 30 degrees, to spray out and down. Put it in the wall, at a low enough height to please the tub user. Costs much less too.
    david
    DIY Junior Member
    Dec 2007
    Whitefish, MT
    Default Laminar faucet woes
    Hello,
    While this thread is old I am curious if vu did indeed install this faucet. Mine was installed in August of 2006. I moved in November 2006 (it's now December 2007) only to find that the plumber knew that the Laminar faucet was not working properly. It sprays water in a four foot circle around the tub. The plumber and my general contractor seem to find it amusing since "they just knew it could never work." Well, I've seen it work and it is gorgeous. Kohler's techs and engineers can't figure it out, but they keep giving the plumbers (different plumbers) ideas. These plumbers tell me that even Kohler is just guessing at this point (and they really have tried). The plumbers are not confident with the latest idea and don't to see me spend any more money until Kohler can come up with a sure fix. I spent $700 extra to try to figure this out. The original plumber is out of business and doesn't answer my calls (he is now if the sprinkler business...perhaps he thought that he was installing an indoor sprinkler over my tub!!!!) His installer has ignored the situation, so the plumber's year warranty is out the window. My general contractor says that his trusted source, another gc, has "installed this faucet all over the world, and they all spray." Yet, it took me 12 Google search pages to find this forum (and it still does not indicate a problem with the faucet), the previous pages are all vendors currently advertising this faucet. So it can't be a problem for too many others. BTW, the online plumber, Designer Plumbing Outlet, is only obligated to the sale for 30 days. (How to buy a faucet and get it installed in new construction or a remodel is a mystery to me.) Any way, their live chat person said I my problem was not their problem.
    Anyone else having problems? Right now I have an 80 gallon, $4500 porcelain pillow storage unit, and have pics to prove it.
    Happy New Year!
