Results 1 to 5 of 5
Thread: diverter question
    Default diverter question
    I have some what new tub faucet with a diverter. the old was replaced due to sticking in the up position (so when you turn on the water , you get sprayed with water) . Now this new one is doing the same thing. I have taken it apart and found no deposit or any reason to cause it to stick. Any ideas?
    What brand and model?
    Default diverter
    I assume you mean a tub spout with a diverter, rather than a faucet with a diverter. If so, it is just because it is an inexpensive one and not intended to work forever. Get a Delta or other brand name one, even though it will be more costly.
    yes it is a cheap one, but they should last more than a couple months shouldn't they? also thanks for the advice.
    Default diverter
    Yes, they should, but that is why they are inexpensive. At least it is new enough that they should exchange it.
