Page 8 of 11 FirstFirst 1234567891011 LastLast
Results 106 to 120 of 151
Thread: Is there a class action lawsuit against Kitec piping?
  1. #106
    Feb 2005
    Talking Zurn --pex Lawsuit
    If it was not already known,
    or If I have already posted this... sorry
    the Zurn brand of PEX
    now has a class action lawsuit against it......
    something to do with the crimp fittings comming agapt....
    Zurn is sold at LOWES, and some supply houses....and I guess it is jsut not holding up well
    the only type of pex that I trust is WIRSBO with the
    plastic expansion clamp rings..... it appers to be about
    the absolute best on the market.
    Rancher.....Ki-tech is considered pex, but it has an allinimum inner core....
    between an outer and innner pex cover.... I have used a little of it,
    and it bends something like soft copper would and stays as you bend it...
    I dont like it...at all..
    The Wirsbo and other pexes are some sort of cross linked polymer
    just solid plastic pipe....
    goto thier web site if you want the chemical breakdown
    god created all men,
  2. #107
    Licensed Grump GrumpyPlumber's Avatar
    Jun 2007
    Licensed Grump
    Quote Originally Posted by master plumber mark
    I've used it extensively on baseboard heat working for other shops, I agree.
    Given a choice of nothing or PEX, I'd take Wirsbo.
    "The biggest regrets we have in life are the chances we never took."
  3. #108
    Quote Originally Posted by ultimachi View Post
    I recently just bought my first house a little over a month ago. One of my water pipes blew and flooded the house while we were asleep. The home warranty company sent out a couple plumbers to fix the problem, but both say that this Kitec plumbing has been recalled and is not repairable. They state that the whole house needs to be repiped.
    Now the home warranty will not cover the cost of repiping the home.....but they also won't approve the repair of this pipe due to the manufacturers recall. They say it has to come out of pocket!!! I also spoke to the homeowner's insurance and they will cover all the damages from the water to the rest of the house.
    So what can I do? Is there a class action lawsuit against the manufacturer? The home warranty company stated that alot of people have filed lawsuits against this manufacturer, but they won't give me any details. I'd really appreciate some direction towards a solution.
    There is a claas action lawsuit seeking to recover damages from defective piping.
  4. #109
    Default IPEX class caction
    My name is Todd Skoglund and I represent a class of individuals seeking to recover damges for failures or bursts in their IPEX hydronic heating tubing in their homes. The tubing at question was installed and/or manufactured between 1999 and 2003. If you have any questions regarding the action filed against IPEX please email me at todd@casey-skoglund.com. SIncerely, Todd K. Skoglund
  5. #110
    For george at repipe, thank you for your input. Your company is very well known thanks to the advertisements for Bill Handel's Persian Palace, on KFI.
    We appreciate your in-depth input on this kitec situation. You can see this thread is about to set a world record for # of posts!
  6. #111
    DIY Junior Member LVDon's Avatar
    Dec 2007
    Las Vegas
    Default Kitec Plumbing Problem/Class Action Suit
    Am new to this site. Live in Vegas and have recently learned that our home has Kitec fittings. Having the house re-piped and have joined the litigation. I would like to establish the date in which the fitting failures were initially documented. Can anyone provide that info or tell me where to look? Would appreciate your sending me a private message along with responding to this site.
    Thanks.
  7. #112
    DIY Junior Member
    Dec 2007
    tx
    Hello all,
    I have read this thread, and being a retired pipefitter with 37 years under my belt (not a plumber). When I bought my house on North Padre Island, TX., Dec. of 2003, it was about 40% done. As being an old fitter, the first thing I saw was that dam Red & Blue pipe. At the time I couldn't find anything bad about it. I personaly em just a copper man when it comes to water pipes. In my house I have the allinimum core between the inner and outer pex cover. Has there been a problem with THIS pipe in your area?
    Thanks for your replys ----------Rich
    PS: Keep up the good work
  8. #113
    Default Failure of Zurn half inch brass female barbed fitting
    I have just had a failure of the brass nut on a Zurn pipe fitting. I will join the class action suit. This whole problem was avoidable. There is nothing wrong with the plastic. It is just that Zurn have chosen to make the fitting out of substandard material and above all tap the thread too fast.
    Here is my story. This is the letter I sen to Zurn, and it contains a copy of the letter I sent to Todd Snodgrass's firm.
    This is what I sent to Zurn. It has the correct link to the damage pictures.
    This is the link: - http://mdcarter.smugmug.com/gallery/3975792#231080554
    Dear Mr Sauer,
    I sending a copy of the letter I have sent to the lead attorney in the class action suit about your pex plumbing fittings. My property suffered damage last night as a result of the failure of Zurn half inch brass FPT x Barb female adapter.
    Fortunately I was home at the time, otherwise property damage would have been in the tens of thousands of dollars. As stated in my letter this failure is a new low benchmark for me in the current race to the bottom among the world's manufacturers. These fittings are concealed, and the potential for significant harm and property damage enormous. Judging by the fact that the fault rate of the fittings I examined in Bemidji today was 100%, I suspect you will end up causing more property damage than the natural disasters of recent years, including hurricane Katrina.
    I own two lovely vintage John Deere tractors here at Walberwick House Benedict. The model A is 60 years old. The fittings are beautifully machined, by fine American craftsmen and machinists. John Deere have always had a contract with the farmer. On the rare occasions in their long history when they have produced substandard product, they have admitted it, bought them back and made restitution. Now farm machinery is predominantly green in North America and Europe. And I'll tell you another thing, I can go to the John Deere dealer and buy new parts for my 60 and 50 year old tractors. More often than not the parts are in stock, and if not they are there the next day.
    What you need to do, is admit the problem. Don't deny it, That is useless, the problem is blatantly obvious. In fact so obvious the case my well be ripe for summary judgment against you. You need to cut this misery short. Get a well made product in the hands of customers to replace the defective parts. And another thing, lets have them made by good American machine shops. You don't state the country of origin, but I would bet it's China, and I very much doubt America. For Heaven,s sake spare American families the agony of severe water damage to their homes. Get a beautifully machined product in the hands of your customers, and a big ad campaign to make consumers aware of the problem and the solution. If you do that you may yet get to become the worlds best manufacturer of plumbing fittings. At the moment you have to be the bottom of the heap. Here is the letter I sent to Mr Raiter which defines the problem.
    Dear Mr Raiter,
    I understand that you are the lead attorney, in the class action lawsuit against Zurn for failure of their PEX plastic plumbing system. Denise and Terry Cox are the plaintiffs.
    We have a beautiful lake home on Benedict Lake Minnesota. It was extensively remodeled Between January and April of 2006.
    Last night at 11.00 PM I went into the main level bathroom. There was water coming through the ceiling, at a fast rate. I shut off the water. I ascertained that the leak was coming from the wall space between the shower and the tub bath, by taking off the inspection cover on the tub. My builder Mr. Stuart Wick of Guthrie came first thing this morning. We had to cut out tile from the shower. We ascertained that there was a large jet of water coming out of the side of the brass fitting connecting the hot water to the shower control. Now I'm a retired MD but I have a large workshop and do a lot of machine work and welding. I have never heard of, nor seen a half inch brass fitting fail in this way. It appeared to me and Mr. Wick and I that it was a defect of manufacture in the thread tapping.
    We went to Lindy's plumbing of Benedict who had supplied the part to get a replacement, but they did no have any. Their Master plumber Mr Tim Johnson, did tell us that they had recently replaced one of these fittings in a local home that had failed in the same way, and done over $80,000 in damages. It thought this was unlikely coincidence. I found out beyond a doubt that Zurn was the manufacturer of my defective brass connector.
    I then went on the Internet and found out about the class action suit.
    I went to Bemidji to get a replacement and found every single one in the store had defective thread tapping! They all had cracks at four spacings of the thread tapper. There happened to be a machinist in the store who over heard my conversation. He examined my defective part and the other items in the store and agreed with my conclusion, that the thread tapper was rotating at far too fast a rate. He also felt that the brass was substandard and likely had too much zinc compared to copper. I was suspicious of that also. In his words, the product was "junk". I took the fitting where the stress lines lined up perfectly with the shoulders of the nut. I thought that was the one least likely to fail. That has been installed and the tile put back tomorrow. The ceiling in the bathroom below needs repair. Total bill for this episode, will be a little over $1000.00.
    State Farm are well aware of this problem with Zurn plumbing fittings. The cost of this repair is about my deductible. They suggest getting the money from Zurn. I have been in contact with their industry rep. He has been conciliatory and has sent me a claim form. However they want me to send them the defective fitting. This I'm reluctant to do. Also on the Internet I have found that Zurn have stopped paying for home repairs due to failure of this product. The other issue is that our home is not safe. This Zurn Q-PEX system needs taking out and replacing with standard copper plumbing. To do this the shower in the master bath needs to be substantially dismantled. In the main level bathroom the tub would have to come out. This will be a big bill. Like Denise and Terry Cox I believe Zurn should pay. What I would like from you is whether or not by joining this suit or suing Zurn individually, I have any chance of getting these needed repairs paid for? I would certainly value your honest opinion in this matter.
    Unfortunately substandard goods, especially from China are far too common. The county of origin of this part is not stated on the part or packaging. Zurn refused to disclose to me the country of origin. However what I have seen today represents for me a new low benchmark in this modern world's race to the bottom. A failure of a half inch brass nut would have been unthinkable in eighteenth century England, but not apparently in the 21st century world manufacturing.
    I'm not an individual who rushes to lawyers and have never sued any one. However Zurn need severe punishment, and need to make proper restitution to their customers. One Minnesota plumbing firm alone has had to deal with 150 of these failures. Apparently 130 million of these have been sold. It seems many are destined to fail over the next year or two, in fact it may well be the majority. This one outfit will likely rack up more in property damage than the last few years natural disasters, including hurricane Katrina. Everybody pays for this gross malfeasance, in increased property insurance. So the damage caused to society by this one $3 item is potentially immense. And that is the other problem, the item ought to cost about $8 to $12 if made properly. A good deal of the responsibility for all of this sort of egregious malfeasance goes right to the front doors of the major big box retailers.
    Here is a link to the pictures I took today.
    http://mdcarter.smugmug.com/gallery/3975792#231080704
    Here are pictures of the home.
    http://mdcarter.smugmug.com/gallery/2467814#P-1-12
    We really can do without Zurn's negligence ruining these nice spaces.
    I await your thoughtful and honest reply with interest.
    Yours Faithfully, Mark Carter MD
    I certainly hope you handle this matter honorably and correctly. If you don't your name will be raked through the mud and I will do more than my share. I think without an honest and fair attempt to make restitution you likely will be put out of business.
  9. #114
    Feb 2005
    Talking you should start another thread about ----ZURN---
    jump out of this Kitech thread and start your own
    thread .....
    This is a NEW HOT TOPIC and you should
    repost this whole comment you made
    so that others will know about this new ZURN fiasco....
    Its everywhere in indianapolis ....literally millions of miles
    of the crap is out there ..sold by major plumbing supply
    houses and also by the knowledgeble fellows at LOWES...
    I am going to be a busy beaver once this really hits the fan..
    You would be wise to just change it all out before other
    damages begin...
    the pic of the actual
    pipe that blew apart ....is that an adaptor that is
    attached to a brass faucet?????
    I really liked your comment
    However what I have seen today represents for me a new low benchmark in this modern world's race to the bottom. A failure of a half inch brass nut would have been unthinkable in eighteenth century England, but not apparently in the 21st century world manufacturing.......
    We the USA have sold our souls to the devil---
    its called Nafta or the new world order....
    or whatever you want to call
    all the cheap crappy junk flooding our shores.
    including the people too.
    as long as the stock market just goes
    upwards into infinity that is all that matters in life.
    cheap goods and slave albor..
    we give our blue collar jobs away to the mexicans and chinese
    and we get poor quality dog crap shipped
    back to us in return.
    Zurn will most likely go bankrupt and or leave the
    country and re-incorporate in Canada just like Kitech did
    Zurn might actually have more of this product out in the
    market than kitech has..
    So I doubt that they will do the honorable thing
    once they realize that their goose is cooked they
    will take theri lawyers advice and they will bail .
    I also liked that photo gallery that you have your pictures on....and I wonder how many can be uploaded to that siet and how quickly
  10. #115
    Quote Originally Posted by master plumber mark View Post
    thread .....
    damages begin...
    Thanks for the tip, and advice. Here is a link to the new thread.
    http://www.terrylove.com/forums/show...629#post111629
  11. #116
    Quote Originally Posted by wet! View Post
    By the way yes, that brass fitting was connected to the hot side of the master bath shower control. The control has a quality brass thread. Never ever expected to see anything like it!
  12. #117
    The Kitec is not the problem, it is the fittings. With the new plastic replacements, the problem is solved. And with the exception of the drop ells in the walls, most of the systems were on some kind of mainifold in an area easy to access. Sorry, repipe guys, but the piping is not problematic, and the cost to fix not all that bad.
  13. #118
    Plumber Cass's Avatar
    Nov 2005
    Seems like if they had spent another 25 cents on the fittings they wouldn't be having the problems and everyone would be happy today and they might even have more $$$ in their company coffers. With the low cost of the piping no one would have flinched to spend a little more for fittings.
    I would say greed somewhere along the line was the culprit.
  14. #119
    Quote Originally Posted by chipperman View Post
    This was a ZURN fitting. It was lousy brass and very poorly machined. I bet this is the first generation in three hundred years, that has managed to make brass nuts that fail!
  15. #120
    I understand the Zurn fittings were bad. I didn't mean to mislead. I haven't had experience with Zurn, only Kitec. The brass fittings were expensive, I'm sure, and the ones I used were well made. But, that doesn't overcome a bad chemical reaction. Brass is strong, machines well, and makes a strong fitting. I think they were forced into the plastic. It seems to work well, and is just as easy to use, but they only make it in a crimp fitting. Trying to fight the various code requirements makes it difficult. I have heard plumbers say the plastic fittings are a fire hazard. By the time they melt in the wall, you will have other problems of a much greater concern.
    And, of course, everyone went to Taiwan or China for the manufacture because of cost, not always equivalent quality. But as any contractor can tell you, the low bidder always does the best work!
