Dialcet was the original Moen twist and pull shower valve. It is just like the current ones, however. The clip is the thin piece of metal sticking out of the top of the brass barrel when you remove the chrome "stop tube". Removing that will probably be the easy part. If it still has a brass cartridge in it, then rmoving it without damaging the faucet may be a job for a plumber with the proper tool (or tools, since it could require more than one tool to do it.)
