Those tanks try to swirl th ewater and keep the crud deposits in suspension. Trouble is, the outlet is at the top, and they try to sink. You need a very strong flow for awhile, but even then, it probably won't cause enough to flow out. Drain it manually, if you are so inclined...that works better, but it may not make that much difference one way or the other if it hasn't been done for awhile.
