Results 1 to 4 of 4
Thread: Water softner experts....
Hybrid View
    Default Water softner experts....
    Hi- I have a G.E. gxsf39e water softner it's about 2.6 yrs old. It softens the water fine (no problems) \, it just seems to regenerate itself every other day and at 32gals per time . It's like doing it 15 or so times a month, does this sound normal or possibily a problem???
    Rancher
    Guest
    How often it regenerates is dependant on what you entered as your water hardness number.
    http://products.geappliances.com/App.../r01513v-1.pdf
    There's the operating manual.
    Rancher
    It sounds as if it s too small for your needs. The largest softener you can get at a big box store is usually a 1.2 cuft. Larger won't fit in any cabinet model; that's where the resin tank is in the salt tank.
    If you reduce the hardness setting, you will not get consistent soft water, nor remove all the hardness between regenerations.
    Thanks for replying Gary & Rancher, I do have the manual but it does'nt really referance any troubleshooting for regenerating (but thanks ).
    On G.E. website they say that model is good for a family of 4 (we only have 3), with normal shower usages. The settings goes as high as 110 which is really soft water, and I have ours set at 26. Just a little confused about why it wants to regenerate every 2-3 days, it does'nt sound normal, unless I'm missing something . I have cleaning everything in there and all filters, fittings and even the old salt in the bottom.
    Could this be normal ??? Awesome forum BTW
