Thanks for all the good input. The well is 170ft, pump set at 160ft, and the top of the water is around 60-70ft. The pipe is 160psi. Don't have a cycle stop valve in the system. The goulds manual recommends a check valve on captive air pressure tanks... at the tank on installations with well seals or well pits... just below the pitless adapter if your system has one of those. I have a pitless adapter but it is only about 15 ft from the tank so I put it at the tank cause I didn't think 15ft would make a lot of difference. The pitless adapter is solid brass , just connects the 1 in well pipe to the house piping, the o-ring just seals the 6in top casing from letting any dirt enter, no pressure on o-ring. From Gould's manual "2.7 CHECK VALVES Our pumps use four different style check valves. We recommend check valves as they prevent back spinning the pump and motor which will cause premature bearing wear. Check valves also prevent water hammer and upthrust damage. Check valves should be installed every 200'-250' in the vertical discharge pipe" I also see the Goulds pump has a check valve. And I sure don't have 200' to 250' of well, let alone verticle pipe. So is any kind of check valve really necessary 60-70ft above the water level? Sure smells like some kind of leak in the well... or a pump problem .. can't think of a lot else. In either case I'd have to look at the bottom end of my system. Is there any value to a check valve at the tank??? or just a mistake??
