Tickridgescott
Hi, I am going to develop a spring on my property. I have to run PE black water pipe approximately 1300 feet. (220 foot up from the spring area to the cistern at the house. I am going to install a submersible pump in the catchment cistern near the spring. My quesiton is water diameter pipe should i use? I was planning on 1". Amount of flow capacity is not an issue. High pressure/low flow.
if 3/4" works, I will use it. I am not sure if 3/4" pipe would cause too much restriction causing the pump to need to be bigger. 1" is not that much more expensive.
