Toto Drake, or ?
fraidycat
I've been pondering new lo-flow toilets, and from all accounts, the Drake looks good. I haven't had problems requiring plungers, etc.,, but I have had to replace the insides on my two enough times that they probably would amount to half the cost of a new toilet and our area has a rebate program which is spurring me on. How is the Drake as to that? Is our hard water part of the problem, or just par for the course?
Second, I have 11" and 11.5" to the wall (not the baseboard). When installed is there a gap or should there be? Can I remove the baseboard and it will set flush with the wall? Can I self-install (middle aged female, fairly handy and strong, but no plumbing experience and would rather not experiment with offset flanges or other unknowns)? I'm looking at cost/function - are there better options than the Drake? Am I assuming correctly that the G-max technology is better than the other Toto flushing technologies, including the dual flush Aquia?
The Toto Drake or Aquia would be a good choice.
The Drake can be installed at 11"
and the Aquia needs 11.5"
Most of the time, the tanks don't touch the wall.
If you have hard water, the Drake with the CEFIONTECT may be better.
fraidycat
Thanks, Terry. Have there been many problems with the Aquia? I see that it, as opposed to other Totos, has only a one year warranty as opposed to the usual five years on the other models.
BSwanson
New York
Toto Drake lo flo
This middle aged woman replaced her toilet (2 piece is easier) with a lo flo Drake. I love it. It also has an offset flange because of a contracter error. There is no problem at all with flush, even with the offset. I would get the sani flush option. I just measured my wall behind the toilet and it has a 1 inch space to the wall. That looks good, but I figure that gives you some wiggle room too.
fraidycat
I decided to go with the Drake instead of the Aquia due to the 5 year vs. 1 year warranty. Got two elongated Drakes installed today and have to say, so far I'm really pleased. Not too loud, the softclose seats are great and a quick tap on the lever seems to provide a dual flush mode. I wimped out and went with a plumber to install because I had an outside faucet that needed replacement (and soldering). My water bill should be a pleasant surprise. Thanks for the help and advice.
TPA
Florida
Just curious, where are you seeing that the warranty on the Aquia is one year? Both the Drake and Aquia are showing 5 year warranties on the spec sheets I have.
fraidycat
Perhaps the warranty has changed? I see the 1 year for the Aquia at several websites but don't know if I can put them here?
Mike50
DIY Senior Member
Southern California
http://www.totousa.com/productpage.asp?PID=803
Toto Aquia has same 5 year warranty as other Toto toilets.
None of the Aquia's in US have aged beyond one year.
They were used in Thailand for 6 years before Toto brought them to market here.
Mike50
