xd2005
- Messages
- 36
- Reaction score
- 0
- Points
- 6
I just finished replacing my galvanized water line from the meter to the house with 1" poly and some galvanized under the house with CPVC. I have a 5/8 x 3/4 meter and, based on my calculations so far, am getting about 47 PSI and 9 GPM (which seemed to be about right based on a chart I saw...correct me if the GPM looks wrong for the PSI). I would like to add on a sprinkler system but am afraid the 9 GPM might be an issue. To run any zone will likely take all 9 GPMs and anytime I try to run anything else at the same time it would be pretty weak. Am I correct in my assumptions?
I am contemplating having a larger meter installed. Thoughts on this? If I do it, should I look at 3/4" or 1"? Price difference per month is $1.55 for 3/4" and $4.90 per month for 1".
Thanks,
Brian
Thanks,
Brian
