Results 1 to 4 of 4
Thread: Happy D Toilet, Duravit
    Default Happy D Toilet, Duravit
    I'm looking at purchsing the Happy D toilet, as it has a 10" rough in and is stylish. The problem I have is that there is a water pressure valve coming out of the wall where the end of the unit should be on the ight side.
    I was wondering whether its possible to cut part of the wall of the toilet to allow for the pipes (the come out aaprox 4 ", which would need to be cut).
    Please advise, if you have experienced a similar issue or whether I need to look for an alternative unit.
    Cutting into a porcelain toilet is almost certainly going to produce cracks, if not immediately, then in the near future. Either move the water supply or choose a different toilet.
    Nov 2005
    i have a Happy D toilet.
    Your question is about the porcelain used to make toilets. Not about the Happy D.
    Plumber Cass's Avatar
    Nov 2005
    Move the pipe.
