Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: Porcher Veneto toilet repairs
  1. #16
    Questions from readers Guest's Avatar
    Nov 2005
    posts, emails and comments from readers reposted by Terry
    How is the flush valve replaced with the plastic liner in place?
    When the cartridge is spun out, how do you thread the new one in place with the liner there?
    Texas
    http://www.terrylove.com/pdf/veneto_parts_3362.pdf
  2. #17
    DIY Junior Member serglo@sbcglobal.net's Avatar
    Oct 2009
    The Woodlands TX
    Gordon did you ever replace the gasket,if so could you tell me how.
    Thank you
  3. #18
    DIY Junior Member 808liz's Avatar
    Jun 2011
    Honolulu,HI
    How do I replace the fill membrane?? Does the front piece just pull off??
  4. #19
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Bumping this old thread.
    Any updates on the Porcher toilets.
    I am looking to add a Veneto Ii to our house.
  5. #20
    DIY Junior Member Rongway's Avatar
    Jul 2012
    Illinois
    Quote Originally Posted by 808liz View Post
    the fill membrane is accessed by unscrewing the big white round nut that is attached to the fill arm.... the nut is about 1 1/4 inch.. you can see it in the diagram. it has no reference number and it just above and to the right of the "9" in the diagram.
  6. #21
    Jul 2012
    Illinois
    My question is how to replace the gasket which is number "7" in the diagram. it is in there tight and has started to corrode. i have found that using Tidy Bowl tablets in this toilet causes leaks in the seals... and those Clorox Bleach tablets are really bad as they break down the rubber parts.
    This is also the original subject of this thread and it was never answered.
    Sorry but what is the purpose of this forum if no one is going to help? I doubt any real plumbers would chime in. They probably don't know themselves how to do it.
  7. #22
    DIY Junior Member ekrumrey's Avatar
    Aug 2013
    California
    I was able to remove the big plastic bolt on the underside as follows:
    Disconnect the top of the supply line (where it comes into the back of the toilet)
    -- make sure you have some thread sealing tape, which you'll need to wrap onto the threads when you put this back on.
    With the supply line disconnected, you can lift the entire reservoir out of the back of the toilet. Now it's simple to grab hold of the big plastic bolt on the underside and unscrew it.
  8. #23
    DIY Junior Member misstca's Avatar
    Sep 2013
    Sacramento, CA
    Thank you ha1976 for the great posting!!! This forum helped me figure out that I screwed up the toilet by using Clorox tabs in the tank. Guillen Enterprises had the piston assembly 83084.00.000 part I needed. It took less than 2 minutes to fix (great picture instructions on the side of the box) and it stopped the leaking! I did also order the membrane assembly 83086.00.000 but it appears that I didn't need it. However I have a packet if I ever do. I think I'm going to order another few of the piston assemblies so I have them on hand for the next 25 years and can hand one off to the next homeowners when we eventually sell the house!
    Now I have to figure out how to safely clean the tank without deteriorating the silicon seal. The inside of the tank got black!
  9. #24
    DIY Senior Member Reach4's Avatar
    Sep 2013
    Quote Originally Posted by misstca View Post
    Got black how? Over time due to sulfur in your water, or was that some reaction to the bleach?
    Anyway, I suggest you start by using a toilet bowl brush in there. See if the black can be brushed loose. Then maybe add some dishwasher detergent. The inside of your tank being discolored should not bother you. If it does, try other cleaning products. If it really bothers you, you should get a new toilet. Since you are fairly adept at changing parts now, you could remove the non-ceramic parts, use strong cleaners, rinse, and re-assemble.
