Thread: Galvanized for DWV
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default Galvanized for DWV
    The main run is CI leading up to a 2" female coupler coming out of the floor.
    Have not decided whether I'll be using brass drain *I have a stash of cast brass traps, tubes, etc* or just do PVC all the way the sink. The coupler is about 3-4 inches below the floor ...so if I decide to go the brass route, I do need to stub it out regardless.
    Would galv. be the best material for this application ?
    Default drain
    There is no "best" material. Use whichever is easiest, or maybe least expensive.
    Jun 2006
    Is galvanized okay for DWV ? I know gal rusts for water supply.....It's easier for me since they come in all nipple sizes...
    From there I can use the brass traps/tube I do have in the garage now
