catrail73
- Messages
- 2
- Reaction score
- 0
- Points
- 0
I had a leaking valve and replaced the entire piping assembly and two valves after too much troubleshooting. I installed two new Lawn Genie 3/4" Anti-Siphon valves. One zone works fine, the second is a problem. The second valve, when turned on manually and / or electronic - the valve starts dumping water from under the cap opposite the diaphragm end. The sprinklers barely pop up. Is this likely the 6" rule I have read on other posts? Both valve sets are level w/ ea. other, but I'm wondering if this is the problem?
Whats the best way to troubleshoot? I should have spent the $60/hr for a technician!
