smoothbore2004
- Messages
- 1
- Reaction score
- 0
- Points
- 0
okay guys here it goes i hope to get some answers for this, I bought a house that has sat for about a year. I installed new pump and tank and was able to get prime so its all good right. Well when i turn on the water it loses pressure and when the pump turns on it cant fill fast enough so it eventually loses prime. I had a plumber come out and check it he says that teh screen in the ground has probably got sediment plugging it up and he recommends using an acid purge proceedure that is suppose to help clean out the sediment on the screen. When this is done it will pull more water so it will be able to keep up when i have the water turned on in the house. He was also able to figure out somehow that i am only pulling about 1 gallon a minute and i should be pulling about three.
My question is does anyone have any input on this as whether they had it done and does it work. I dont want to waste my money if this is a waste of time. Any other suggestions would be appreciated.
