If you needed an ejector, you should already have a basin and pump installed or a pit that receives the drainage, but still needs a pump. Basically, if the drainage lines for the upper floors goes through the floor of the basement (and you see no evidence of any kind of barrel or pit in the floor of the basement), the drainage lines are most likely gravity drain. Do you have a line coming out of the ceiling somewhere for the vent?
Deb
The Pipewench
