Okay! I think my pump is trying to drive me and my husband insane! Help me please. I live north of Montreal, Quebec, Canada.
We have a:
Shallow well with lots of water in it (we checked and we're tapped into a underground vein of water)
Mastercraft 1/3 hp jet pump
Red Lion captive air tank model R14 #604456 (max working pressure 100psi)
and a really big head ache!!!
About 3 weeks ago, when we would use the water, after about a minute, the water would cut out on us and then start up again after a few seconds. Then those few seconds would get longer and longer. Until, you'd be in the shower and it would cut out for like 10 minutes. We checked the pump and the pressure gage said 0 and then it would build up and work. We were asking around if anyone knew why but were getting different answers.
About a week ago, the pump started working all the time. The minute we realized the pump was on even when no water was being used, we unplugged it. Because my husband was working so much, he couldn't get to it right away, so we would plug in the pump when we needed it (flush the toilet, take showers,do dishes and fill containers) , and unplug when we were done. Once he could get to it a couple of days later, it went caput! We plugged in the pump and nothing happened.
My husband has gotten it working again by installing a new the pressure switch (i think that's what you call it) it's a 30/50. Then it wouldn't keep the prime so he pulled up the pipe in the well and discovered the foot valve had come off. He installed a new foot valve, the check valve, and got a new gage for the pump.
Now we have very low water pressure and the pump will get hot were the water comes in (at the front of the pump),
Is there something that needs to be tweeked? Can anyone help??? before my husband takes a sledge hammer to the damn thing?
I don't know if this info will help any, but last summer we changed ALL the plumbing in the house from old ratty 1/2 inch pipes to 3/4-1/2 inch flex-pipe.
(3/4 mains to 1/2 inch run offs). Could this mean we need a stronger pump? Is this part of the problem?
Thank you for reading this long thing. any help will be DEEPLY appreciated.
We have a:
