Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 63
Thread: Caroma Dual Flush watersense toilet review & pictues
  1. #46
    If you family member is part of the top 1% that plugs a 2" trapway,
    Then pick up a Caroma toilet.
    The trapway is 3"
  2. #47
    DIY Junior Member lazypineapple's Avatar
    Jan 2010
    Texas
    Thanks for the reply, but after reading reviews here. I not sure this would be a good choice , for them.
    I should have mentioned, this would be used by elderly people..and being old skool. and techniqe changes ,I might not have a happy Parent.
    so what would the second choice ?
  3. #48
    If, either because of diet, medications, or who knows, a person produces huge, hard stools, then the larger trapway of the Caroma can handle it better than the others that are available because of the size. For more normal people, any of the Totos is hard to clog. Nothing's impossible, but they are much better than the norm. If their current toielt is clogging because it is a lousy toilet, a Toto will resolve that. If it is because of medical problems, you choice is a stick to break it apart before flushing, or a Caroma. ANd, even then, it might be possible to clog if you used enough paper, but doubtful.
  4. #49
    DIY Junior Member chrisf8657's Avatar
    Feb 2010
    Phoenix, AZ
    jadnashua's right, I used to get a bunch of paint stir sticks out of Home Depot everytime I had to break the big ones up. The Cadet 3 EL Flowise I have, and Toto Drakes, are difficult to clog, I havent clogged mine yet, though I could easily with my old '82 Kilgore. Never heard of a Caroma, though.
    My review:
    http://www.terrylove.com/forums/show...Flowise-Toilet
  5. #50
    DIY Junior Member Pipefitter's Avatar
    Mar 2010
    outside Vancouver
    We had our Caroma Caravelle toilets, 2 of them, installed about 2 years ago. For the first year or so they worked without a problem, however , lately the flush water seals need periodic cleaning and the "stainless" metal parts are rusting. I don't believe that the our local water treatments can be corrosive enough to do this, but I can't find and other reason for this occurrance. Secondly, I talked to the local Caroma rep regarding the seat problems and she told me that it was normal to have the seats cleaned every "couple of years". I am wondering if the seals could be degrading from exposure to water treatment chemicals as well. If the flush water seats aren't functioning properly, the toilet is no longer a water saving toilet. Has anyone else encountered this and is there a resonable fix to these 2 problems?
  6. #51
    Comments by readers Reader Review's Avatar
    Jan 2006
    Default Caroma Bondi 270
    Terry,
    I recently replaced my inefficient toilet with a Caroma Bondi 270 Easy Height Elongated toilet. I wish I could say I am completely happy with it, but I can’t.
    The three-liter flush leaves behind the toilet paper most of the time, and the “water” that is left doesn’t look as clean and clear as it should (water from the tank is clean and clear). The six-liter flush won’t completely eliminate solid waste most of the time. There is usually a small amount of something floating on top of the water, sitting on the bottom of the bowl, or both. I am not impressed, and my guests are even less impressed. Another half-flush usually solves both problems, which only partially fulfils the reason I changed toilets. For over $400 (Cdn) I expect better performance. Also, it puts into question the reliability of the MAP data (Bondi is rated at 900 grams), at least from my point of view.
    Bob W
    Brandon, MB Canada
  7. #52
    Jan 2006
    We bought a brand new house 2 years ago and it came with the dual flush Caroma. It is great except that after 2 years of use, it leaks. Both of our toilets leaked after 2 years of install. Repair is costly. Given the chance, wont do it again.
    M&E
  8. #53
    DIY Member TWEAK's Avatar
    May 2009
    Bay Area CA
    My only experience with a Caroma was in a hotel in Oceanside, CA. Great looking toilet, I really like the styling -- and a powerful flush. However, it has two flaws that, for me, rule it out. The first is that the water level is just WAY too low, and the bowl wash effect isn't good. The bowl gets messy. I have *zero* desire to brush the toilet after every use... and lining the bowl with paper just sounds silly. The other problem is that if you flush while still seated, you are quite likely to have some of your male anatomy involved. Including some splash? Not so good.
    I recently put in a Toto Guinevere. While I was mildly disappointed with the styling of the skirt, IMO it's overall a much, much better functional design than the Caroma. It has a good, high water level (Guinevere is a single flush - dual flush often has low water level), strong enough flush, and the cyclone system ( or whatever they call it) washes the bowl pretty well and doesn't splash a lot.
  9. #54
    DIY Junior Member dgrubb109's Avatar
    Mar 2011
    Sacramento, California
    Default Caroma Toilet - Sydney 305/270
    Does anyone know about the Caroma Sydney Toilets - 305/270? I know they are different than the standard toilets, and are made in Australia. They are also offering very good rebates in the city where my house is located. However some of the plumbers I have spoken with do not recommend them, while others say they are okay. Pros and Cons anyone?
  10. #55
    Caromas may be the only choice for a very small percentage of people that for some reason produce large/long/hard stools. Other that that, they aren't the best toilet out there. They have their place, as they are essentially one of very few toilets with a 3" trapway. Most toilets doe quite well with smaller diameter ones (well, there are some dogs out there, either in QA or design). Unless you are in that 1% or so, I'd look at a different brand (my preference would be a Toto).
  11. #56
    DIY Junior Member adrialla's Avatar
    May 2012
    TX
    Thumbs down Unsanitary and disgusting
    Quote Originally Posted by TWEAK View Post
    I couldn't agree more! We moved into a rental property that has a Caroma dual flush toilet. With such a low water level, waste residue collects in the bowl that does not get washed off when flushed 3 times, let alone once. I detest having to grab a wad of toilet paper and manually remove the residue or use the bowl brush to get it out, which then necessitates soaking the brush in bleach each time to disinfect. If the bowl isn't thoroughly cleaned after each "productive" visit, the bathroom gets a distinct odor. I also concur with the issue of flushing while seated, especially during a bout of gastrointestinal trouble. Plan on taking a shower after the violent splashback.
    These toilets may save water, but they are completely unsanitary and a health hazard IMO.
  12. #57
    DIY Junior Member DavidDIY's Avatar
    Oct 2012
    Michigan
    Default size of flange with Caroma toilet
    The quick version: Does a Caroma toilet need a 4" closet flange and pipe or would a 3" pipe (with a 4/3 flange) be ok?
    I am currently working on a major master bathroom remodel that will not be done for a good long time. Working in my spare time doing all of the work myself and - most importantly - paying for it all yikes. Among the many decisions I have to make is a toilet. I am leaning toward a Caroma at the moment for the extra wide trapway. I ran across a post where Terry stated that the Caroma 4" trapway narrows to 3". Everything I read from Caroma says "full 4 inch trapway" which led me to think I might have to use 4 inch all the way but not so if it narrows to 3". I was wondering if this is current information (don't remember the date on that post) and if it is all Caroma models or at least the ones available here. That is the kind of information I would have expected Caroma to make available. It also would seem that narrowing would be bad, especially in the trapway but they are supposed to be the experts. Since my plumbing is in the rough in stage and no subfloor in yet I can change some things if I need to.
    Found you by way of Google. Great work going on here. Thanks for all the great discussions I have already been able to digest thus far.
  13. #58
    Caroma likes to say 4" trapway. And I liked to believe in Santa Clause when I was young. But then you grow up and find out that not everything you read is real.
    The Caroma 305 bowl has a 3" trapway. At least on the outlet. The Caroma 270 bowl is a bit larger then 3", and as it folds over, certainly less then 4".
    Installing the 305 bowl with the 3" outlet over a 4x3 flange work perfectly.
    The 270 bowl is a little larger with the supplied adapter, but I have installed plenty over a 4x3 closet flange.
    By the way, Gerber says their Ultraflush trapway averages over 3", and yet when I put a tape measure on it, it's 1-7/8" at the outlet.
    Below is the Caroma 305 3" trapway.
    A Caroma 305 bowl with 3" trapway. I wish I had taken the picture with my tape measure across the opening.
  14. #59
    DIY kid who loves toilets Starwarsith88's Avatar
    Aug 2013
    Sparta NJ
    Default Caroma Toilet Review
    What do you guys think of the caroma? I want to get a dual flush one but is that model the caravelle? I want one that is really high performance and flushes well.
    If you need to go with a new toilet, go with a TOTO!
  15. #60
    There's good and bad with the Caroma - the good is that they have probably the largest diameter trapway in the industry, and will flush the long, hard logs some people (maybe less than 1%) of the population produces, usually because of some medical condition. The bad is that to get the water moving in such a large trapway requires dumping the water VERY fast, which typically can splash the bottom of the seat (and you, if you're sitting there...best left to flush only after you close it! If you're in that 1% that doesn't produce 'normal' deposits, it may be your best bet. But, most any Toto will be perfectly fine for the rest. Ask someone who has owned one for awhile, and see if they still know where their plunger is...they probably don't. There are others.
  1. Toto Aquia dual flush toilet product review, comments and posts.
    By stimpsonjcatt in forum Toilet Forum discussions
    Last Post: 01-27-2014, 09:32 AM
  2. Costco Water Ridge Dual Flush Toilet Review & pictures
    By Bobbyboy in forum Toilet Forum discussions
    Last Post: 12-11-2013, 11:07 AM
  3. Replies: 16
    Last Post: 09-07-2012, 02:41 PM
  4. Replies: 2
    Last Post: 03-11-2011, 12:58 PM
  5. caroma dual flush - toilet seat headaches
    By godhelpme in forum Toilet Forum discussions
    Last Post: 05-17-2008, 03:05 AM
