Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 63
Thread: Caroma Dual Flush watersense toilet review & pictues
  1. #31
    The Caroma Sydney comfort height round 270 bowl
    The side of the 270 bowl
    Where the seat attaches
    Like many dual flush toilets, there isn't much water in the bowl.
    WaterSense Toilets in the Seattle Area
  2. #32
    The 270 bowl uses an offset adapter so you can adjust the rough-in from 12" to 10"
    Underneath the Caroma 270 bowl.
    Inside the Caroma Sydney tank
    Dual Flush buttons
  3. #33
    DIY Junior Member caroma-305's Avatar
    Dec 2009
    Texas
    Default issue with CAROMA 305 DUAL FLUSH
    installed CAROMA 305 DUAL FLUSH few days back.
    one bigggg issue is , the "water level" in the BOWL (not the tank), is so low, the porcelain gets dirty, and requires cleaning,
    the "water" filled matches the "water level marker" in the TANK.
    the 'three' tower like components are so complicated for me to understand, and very flimsy.
    any way out , to increase the water-level in the bOWL.
    please help
  4. #34
    Normally, no. If for some reason the fill valve is not working properly, in theory it is possible.
    Take a bucket of water. Slowly pour it into the bowl. Let it sit for a minute or so, then check the level. If it goes up and stays up, it's a fill valve issue. If it won't stay up any higher, that's just the way that toilet is designed, nothing you can do about it except replace it with a different model.
    Note, the dual-flush toilets can't have all that much in the bowl, because even on a low flush, it still needs to evacuate the entire amount, and refill. To keep the volume down, they can't have all that much in the bowl.
  5. #35
    The Caroma has very little water in the bowl,
    and they stay dirty.
    But that has been commented on before.
    I don't sell very many of the Caroma anymore.
    How do you like the droplets of water on the seat when you flush it?
    That's a nice bonus too.
  6. #36
    Yakima WA
    The water level (aka water spot) in the bowl of any toilet is determined by the construction of the internal trap and is not adjustable. One of the things I really like about my Toto Dartmouth and Toto Drake is the large water spot.
  7. #37
    Aug 2009
    Midwest
    Yep, I like the way Toto designed the wide but shallow waterspot. The problem being described with the Caroma is one of two reasons I decided against them. (The other was the potential for spraying material out of the bowl as I've seen in a vid.)
  8. #38
    Dec 2009
    Texas
    Default thanks
    thanks for the info, What model of DRAKE do you recommend.
  9. #39
    Dec 2009
    Texas
    Default replace?
    thank you for the info. Its only 3 days old, will local-hardware store take it back, and replace it for TOTO models. (iam hesitant to do this, but iam dissatisfied with the product)
  10. #40
    Plumber Cass's Avatar
    Nov 2005
    Call and ask about it....they may take it back...
  11. #41
    Aug 2009
    Midwest
    Quote Originally Posted by caroma-305 View Post
    My guess is that they won't actually carry Toto or their prices might be out of line if they custom order these. I would see if I could just return it for refund even if I had to take a "restocking charge" for it. For Toto's you often will need to call local plumbing supply houses for pricing. You might be able to forego freight costs by allowing delivery with their standard distribution runs.
    Since you went with dual flush I assume you will want an EcoDrake model (1.28 gpf) rather than the older standard 1.6 gpf tank. I suggest adding the Sanagloss option for the cleanest possible bowl (I debated this and went with at, supply house only charged something like $20 extra for it.) Choose ADA or standard height, elongated or round according to your preferences.
    You can either get the standard bowl rinse Drake or the double cyclone Drake II. I have not ever used the double cyclone so I have no comparison.
  12. #42
    To be fair about the Caroma, and Cass knows this too, they don't plug.
    They are from Australia, where water is critical.
    In order to maintain a dual flush, there is very little water in the bowl,
    The Toto Aquia dual flush has very little water too, as do almost all other dual flush toilets.
    The Aquia does stay a bit cleaner, but for what it is, the Caroma works as advertised.
    I sold dozens of the Caroma 305's to the National Park Service.
    I do like the Drake models though by Toto, and the Aquia, which has been very good.
    For some people with medical problems, the Caroma my be the only solution. The trapway on the Caroma is the largest on the market.
    Most modern bowls do very well with a 2" trapway.
  13. #43
    Dec 2009
    Texas
    Default thank you
    thank you very much. appreciate the inputs.
  14. #44
    Dec 2009
    Texas
    Default update--
    quick update.
    Found a way out , to keep the porcelain clean,
    Before using the toilet , we flush it, (the Min-Flush) , drop folded toilet-papers around the porcelain wall
    this sure a inconvenience, but keeps the porcelain clean & prevents he after-work with the brush ;-)
    water savings , with little pre-work !!! (PS: not a good toilet for guest-bathroom... no way)
    thank you.
  15. #45
    DIY Junior Member lazypineapple's Avatar
    Jan 2010
    Texas
    Default Largest trap?
    I notice that most toto's have a 2-1/8 trap some have a larger trap.. 2-7/16
    is the larger traps much better flusher ?
    looking for a 2 piece great flusher,
    a certain 90 pound family member and jam a toilet. dangest thing i ever seen, and Im not talking with paper.
    thanks
  1. Toto Aquia dual flush toilet product review, comments and posts.
    By stimpsonjcatt in forum Toilet Forum discussions
    Last Post: 01-27-2014, 09:32 AM
  2. Costco Water Ridge Dual Flush Toilet Review & pictures
    By Bobbyboy in forum Toilet Forum discussions
    Last Post: 12-11-2013, 11:07 AM
  3. Replies: 16
    Last Post: 09-07-2012, 02:41 PM
  4. Replies: 2
    Last Post: 03-11-2011, 12:58 PM
  5. caroma dual flush - toilet seat headaches
    By godhelpme in forum Toilet Forum discussions
    Last Post: 05-17-2008, 03:05 AM
