Thread: Flange Too Close To the Wall
    Default Flange Too Close To the Wall
    I just installed a brand new toilet in a bathroom that has been remodeled. I installed the bowl using two wax rings, because a layer of new tile caused the flange to be slightly lower than it used to be. This trick seemed to work, as the floor bolts tightened up nicely, as the toilet squished down on the wax. When I went to install the tank, however, the holes did not line up, because the tank was hitting the back wall and needed another 3/4" of space.
    I loosened the toilet floor bolts and literally dragged the toilet forward until the tank and bowl holes lined up properly, and then I installed the tank. When I went to tighten the floor bolts, one of them tightened up good, but the other one pulled through the flange. There's no leaks, and the toilet doesn't rock at all.
    I've used flange repair kits when the flange is broken, but this flange is not broken--just needs to be moved forward a bit. What do you all recommend?
    Plumber Cass's Avatar
    You can try remounting the toilet on the flange and pulling it forward a bit B4 tightning the flange bolts. You will also see why the bolt came off the flange. Mark the floor in the back of the toilet bowl with a pencil so you can tell if you are forward of where the toilet was last mounted.
    Default flange
    Flanges cannot be "moved forward a little". The bolts normally cannot pull through the flange unless it is damaged. If the flange has elongated slots you can place the bolts where you need them, then secure them with additional nuts and washers against the flange before setting the toilet.
    Quote Originally Posted by hj
    I'm sure that if you bust up the floor and repipe the drain or use an offset flange it can be done. But I like the idea of securing the bolts tightly down on the flange with separate nuts and washers at a position on the flange where the tank has enough room. Serves me right for not installing the tank first and then doing a dry run without wax or bolts!
