Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: Mudding drywall screws (tricky little suckers got you screwed)
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    Default Mudding drywall screws (tricky little suckers got you screwed)
    It's easy to put a lot of screws in drywall. More the merrier right? I thought it would be best to err on the side of too many than too few. I mean, hey a little paper and gypsom to a sea of screws can't be all that bad, right? Just kidding.
    Anyhow, I've gotten pretty good at mudding joints, but what about the fasteners? When properly nailing drywall, you get a nice approx 1" circlar dimple around the nail. Fills in nicely. When you screw it in you don't get that.
    Should I hump up the mud just smigen around the screw(s) or should I just fill in the 1/4" circle around the screw head flush?
    When I see professionally done drywall I see a long smear (for lack of better words) of mud around the row of screws. Isn't this creating like a little 'speed bump'?
    What should I do? I've got 750sq/ft of drywall to finish... *sigh*
    Jason
    Quote Originally Posted by Lakee911
    t that.
    Jason
    I like to countersink my drywall screws, so the screwhead sits a tad below the plane of the drywall. When I'm all done, I go back and mud over the little depressions, screw head and all. If necessary, I sand these little spots when I'm sanding the seams nearby. No humps, no bumps!
    Verdeboy is right. Countersink them and try to put your nails or screws next to the seams, that way when you mud, you are mudding over the tape and the screws at the same time. If you put a couple screws in the middle of the drywall to make sure is doesn't vibrate during deep noises then you could do that as well.
    It will take a more than a couple in the middle, and don't get too close to the edge. Just be sure when you countersink that you don't break through the paper.
    If you have a lot to do, you would be best served by renting or borrow a drywall screw gun. They can be adjusted to set the screw to the right level every time. I have also seen, but not used the adapters, which fit on the end of a drill.
    Paul
    Plumber jimbo's Avatar
    http://www.dewalt.com/us/products/to...p?productID=39
    A proper screwgun will recess the head of the screw just the right amount. There will be a smaller dimple than when using nails, so when spackled flush, it should be a very small white dot.Most drywallers use the technique of a sideways smear over a line of screws, but they come back over that with the 4" knife for a flush pass.
    A vs drill will work just fine. You'll get the touch pretty quickly. When properly countersunk, screws'll hide better than nails bkz they won't pop as readily.
    Hope you framed with dry lumber...I once framed a wall with SGreen and drywalled too quickly. The wall shrunk and a huge seam opened up.
    (important note: I'm not a pro)
    Central Florida
    The "touch" prashter refers to is pretty critical. you have to sink the screw enough to ensure the head is below the surface, but not enough to break the paper. PEW's suggestion to rent a screw gun is a good one. There are various recommendations for how many screws, but I try for 8-12" between screws -- don't leave any large gaps. So far good. The key to easy hanging is proper framing, so you've always got a good place for the screw to grip without being too close to the edge.
    The building codes do specify the maximum permitted spacing between scrwes or nails. I dont remember the number. When my condo had to sue the builder over some issues, the lawyers bring in construction experts to examine EVERYTHING. We didn't have any issues with drywall, but they just try to find anything to run up the tab. You need to get a lot of money out of the builder knowing that if a few drywall screws are 13" apart instead of 12", that money will go in the pot that the layers take 30% of. Hopefully, there is enough left to fix the things that really need fixing, like the roof!I remember these guys in coat and tie going over my living room walls with little magnets, marking each screw with a dot of tape, and then some guy with $10,000 worth of camera equipment takes pictures of it all!
    Aug 2005
    Columbus, OH
    Ok ok ... Sorry I didn't word it right.
    My screws, all billion of them ARE countersunk nicely w/o broken paper.
    The two ways I meant to covey:
    First way: Filling the depression and smoothing flush w/ the surrounding paper.
    Second way: Filling the depression and humping it up, ever so slightly (like you would do w/ auto body filler on a body panel) around the screw. Mud covers a much larger area and isn't just a 'lil plug.
    When I saw pros do it, it appeared like they're doing it the second way because you see that big smear of mud down the whole wall for all the screws. Then after I did some the first way (and second way), I noticed that if I even wet the paper w/ the mud and scrape it all off, it still turns white!
    So, I guess the first way is best. Less sanding overall.
    Things are slow going cuz I got no stilts and I'm moving the ladder around. Hopefully first coat of mud will be done by Friday night. Then a little sanding.
    I picked up a Sand&Kleen MT800 (http://www.sandkleen.com/products.htm) last night from the Orange Box store. It's a piece of junk, but worth while for the price. $45. The problem with it is the vacuum. It elinates 90-95% of the dust, but with enough vacuum to grab the dust it sucks the sander into the wall and sands too hard. With less vacuum, it doesnt' suck enough dust. I think I'll sand the first couple of coats with it before switching to a borrowed Festool sander and HEPA vacuum on low speed w/ very fine paper for the last coat. The Porter Cable sander is out of my price range unless I resell it and I don't think I wanna hassle w/ it...unless I can borrow/rent someones sander
    Thanks for the advice,
    Jason
    Aug 2005
    Columbus, OH
    BTW, my screws are 6" apart on the edges and 12" apart in the field. Sometimes my screwer would get carried away and put them 6" apart in the field. It ain't going anywhere.
    screwer = girlfriend. She's good at nailing and screwing--get your mind out of the gutter. She wields a mean circular saw too.
    Jason
    It take 2 or 3 coats of mud over the screws. The first coat just fills the hole. When is it sanded, there will still be a depression. The second coat is wider than the first, and the third wider still. Sand between. The reason is to lessen the likelyhood of it being visible. If you only put one application on, when the wall is painted, every hole will show. The same principle is used when taping. First coat over the tape, each coat after that is wider. Note the coats are very thin and are sanded inbetween applications.
    Central Florida
    Default Sanding?
    My drywall god doesn't believe in it. He's finished my whole house, and doesn't even have sandpaper in his truck, I don't think. I can't believe his touch with a 16" blade. When he's done with a wall, it's ready for paint.
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    Too late for you now but there is a little adjustable device that goes in your drill that you can set to get consistent setting of the drywall screws. It has a socket for the bit and disengages from the screw when it reaches the set depth.
    Aug 2005
    Columbus, OH
    Quote Originally Posted by Mikey
    That'd be great. Sanding is a ^%^%^$%!
    ... She wields a mean circular saw too.
    You lucky dawg. My wife won't even step into my shop except to yell at me for making too much noise and dust.
