rlmaier
To all,
I've got a few questions regarding the attached drawing. I'm planning on roughing in a toilet and a sink. The toilet is on one level and the sink will be standing on a slab 40†below the toilet. I'll have a 40“ high - 12“ block wall separating the two fixtures with a 2 x 4 framed wall on top of the block wall.
I'm planning on using 3" pipe from the toilet and using 2 - 45 degree elbows to get down to where the sink drain goes through the block wall. Somewhere below the second elbow I’ll install a 3x3x2 wye and vent it back through the block wall to a 90 degree elbow and then up to the 3†vent through the roof. Are there any requirements that the 2†vent pipe must be at a specific angle (toward vertical) going back to the block wall? Finally, I'll connect the 2" sink drain into the toilet drain via a 3x3x2 wye.
In terms of the venting the sink, can I use a 2" sanitary tee in the middle of the block wall to vent the sink? Is there a problem with the 2" tee being too close to the sink trap? I read somewhere that this might not be the proper use of a sanitary tee?
I realize I can put a clean-out either before I exit the building or immediately after exiting the building but does anyone see a problem if I install a 3x3x3 wye below the toilet and create a clean-out behind the toilet? Is that a bad idea?
As you can see, I'm proposing running my main drain line entirely on the right side of my block wall - mainly because the ground will already have been excavated and should ease the plumbing rough-in and provide plenty of drop for the drain. The other choice is to take the more direct route and drop the drain and soon as possible and go through the block wall, and under the lower slab. Is there a big advantage of one way versus the other? Is one more problematic than the other?
And finally, are there any concerns with running schedule 40 pipe immediately adjacent to the block wall (in the gravel, under the slab)? How deep should the pipe be buried in gravel below the concrete slab?
Sorry about being so long winded - any help is greatly appreciated.
Reid
Reid
