Results 1 to 2 of 2
Thread: Double fixture fitting inlet length
    Default Double fixture fitting inlet length
    Is there a minimum length requirement (UPC) between a double fixture fitting and closet flanges used for back to back toilets. Another thread alluded to this. I wish to use a 10" rough-in toilet on one side which puts the length from centerline of toilet flange to centerline of DFF vent at about 12.5".
    Is this wrong? Thanks,
    Hazel
    Nov 2005
    hazel
    to get feedback, of higher quality, and more complete, and faster, post a diagram or two, and keep refining them. Stick to one thread and post a link to that thread in all the other threads you start or post to.
    I have back-to-back toilets. They are wall-mount with Geberit carriers. May not be much that is useful for you to know. To connect the two, a Master plumber used one Wye and one San-T, whic is permissible since venting comes down from above and vents the first one, the San-T, and then the Wye is emptying into an already vented stack. The only other optin I had was to buy a back-to-back fitting from Geberit for this, but that i repeat was for wall-mount rear-dischareg toilets, not necessarily relevant to your situation but still good to know.
    DAvid
