Did you turn the cut-off valves on?
This week I itstalled a new bath tub. The water was off for 3 days. Now everything works but the bathroom sink in the same room I put the tub in. What would cause this. Thanks in advance.
The only thing I shut off was the water main coming into the house. There are no other water shut offs.
Did you tap into the same line as the sink? Did you stick something in the pipes to stop the water flow so you could solder? Maybe you forgot to take it out?
Both hot and cold don't work?
Pull off the aerator and either clean or replace it.
