Thread: Is it toto drake
    Default Is it toto drake
    Hi Folks,
    I just now bought and received toto drake in ADA style CST744SL. I have a quesion, should/does it show the model number/name on the bowl somewhere. On the bowl it only shows Toto 1.6Gpf. I am being a little paranoid to ensure that the toilet I got is actually Drake model as there is a very close model cst704SL which is very close in cst744sl spec wise but much cheaper.
    Thanks for any input.
    Plumber jimbo's Avatar
    I did not find the CST704 on the Toto website. The boxes the toilet came in should be clearly marked with model numbers. The bowl is C774 and the tank is ST774. Typically, bowls do not have numbers on them. Not sure about Toto. There may be numbers stamped on the underside.
    Toto Drake CST744S, standard height model.
    The box for the bowl would have said, C744SL for the ADA model
    The tank would have been a ST743S
    If the toilet looks similar to the picture above, but taller, I would think you had the ADA Drake.
    The 704 model has a much different trapway design.
    Thanks. I think I have the right model, though there are no markings on the box.
