JohnyChevyEG
I have pretty good experience soldering electrical devices, so I didn't think soldering copper would be too much different. After having tried it today, I dont know if I'm doing it right. All the internet research states to apply flame to the fitting, and remove before applying solder. I could never get it to do this, so most of the time, i had flame on the fitting while i was putting the solder on. It seems to work, I ran out of solder before I could finish and run some water, so I dont know 100 percent. The only thing is the existing pipe and fittings look a lot different, like more solder was used on them then what I did. I tried to put as much solder as they did, but it just dripped right off the pipe, so I could never get it to look like that. I just think maybe I'm not doing it right. What are some tips you guys have for me? I'm having fun doing this though, so I guess it's all worth it.
Also, when tapping into an existing 3/4 inch supply, what are some tips for bending the pipe enough to slip the t-fitting on?
Also, sorry, when cementing pvc, how long do I have to correct a mistake before it's too late? I'm going to be installing a toilet tomorrow, and cutting the 3 inch stub out to slip the flange on it, and i'm worried that I may not be able to get the flange How far under the concrete should I cut the pvc? Is there some sort of cutting tool that I can use from the inside in, because it's going to take a while cutting the pipe past the first cut that will be level with the concrete. maybe thats all I need????
