Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: how does electric sprinkler valve work?
    DIY Junior Member oldanbo's Avatar
    May 2006
    Sequim,WA
    Default how does electric sprinkler valve work?
    I am having a problem with what I believe to be a leak in my irrigation system. I called a professional to get an estimate for finding and fixing a leak. He proceeds to tell me how they check out all the wiring and solenoids and valves etc. "That's good" I think to myself, but the sprinklers work, I think one of the underground pipes is leaking when (whichever of the 8) the station is turned on.
    Then this guy starts telling me that the valves/solenoids don't work the way that I think they work. IE, when power is applied the solenoid is activated and opens the valve. He said it works just the opposite, the valve is normally open allowing water to pass and it closes when power is applied.
    Seems to me that this guy may not be snapping on all of his synapsis.
    Can anyone on here give me the staight scoop?
    Regards,
    Dan
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    Valves are closed when the solenoid in not activated. Otherwise, all of your valves would open if the power failed.
    Most electric irrigation valve are "pilot operated". The design is made so that water pressure and a spring work together to keep the valve closed. The solenoid opens a small "pilot" passage to relieve the water pressure in an area that is keeping the valve closed, allowing the pressure on the supply side to open the valve.
    By using the pilot operation, the solenoid doesn't have to be strong enough to keep the valve closed against the pressure. That reduces the cost of the valve.
    Pilot operated valves require a certain minimum pressure to actuate the valve.
    Default valves
    Some hydraulic, i.e., water operated, valves are normally open with the water pressure keeping them closed, but since the only way they could open accidently would be if the water pressure was shut off, the system would not have any water to flood the area. All others are normally closed, and if the spriinkler guy tells you otherwise get a different sprinkler guy.
    May 2006
    Sequim,WA
    Default Yes, that's what I thought
    and I appreciate the detailed replies.
    Seems to me that it would be a wise move to install a backflow preventer on the main sprinkler line rather than relying on each electric valve to work individually.
    DIY Junior Member PSLawnService's Avatar
    May 2009
    Minnesota
    Your lawn professional person was correct. It is slightly more complicated than the other posters stated.
    Major components to the irrigation valve.
    1 The valve body
    2 The lower camber
    3 The upper camber
    4 The diaphram separating the two chambers
    5 The spring above the diaphram
    6 The 24 volt solnoid
    When you are starting your system in the Spring water will flow and fill the lower chamber in the valve body first. A small tube or passage way will allow the upper chamber to fill with water next equalizing pressure on both sides of the diaphram. The spring on the top side of the diaphram exerts pressure causing the forces to be un-equal keeping the valve closed.
    When electric current activates the solnoid, the small tube or passage way is closed. (The electricity is CLOSING the previously open...) The water pressure is lessened on the top side of the valve allowing the water source to force the diaphram up....opening the valve. The reverse happens when the valve is closed.
    Plumber jimbo's Avatar
    [quote=PSLawnService;201628]
    (The electricity is CLOSING the previously open...) quote]
    You had a good explanation up to this point. But then it is wrong. When the solenoid is activated, it does not CLOSE a port, it OPENS another port which allows water from the top chamber to flow into the outlet, thus lowering the pressure in the top chamber, and then water supply pressure overcomes the spring, and the valve opens. The manual bleed screw which many valves have does the same thing.
    This is the way every valve I know works.
    DIY Member rayh78's Avatar
    Sep 2008
    Virginia
    My valves have no power available to them in the winter since I unplug the transformer. And they stay closed.
    Like others said. If it was the opposite, then whenever the power went out everybodys lawn sprinklers system would turn on.
    I only need mine 6 months out of the year so I disconnect power to save the eqipment and a tiny bit of power.
    May 2009
    Minnesota
    First answer - How does the water get into the upper chamber in the first place?
    The solenoid stops the flow from the lower chamber lowering the pressure, the manual bleed releases water from the upper chamber thereby lowering the pressure.
    May 2009
    Minnesota
    To rayh 78,
    Do you leave your water turned on?
    If you turn your water off, how do you know if the valve is open or closed??
    May 2009
    Minnesota
    My entire response to rayh 78 did not appear in the post.
    Water pressure is required to open and close a valve. Electricity is just the automated way.
    Turning off the electricity will NOT open the valves.
    Note- Valves under water pressure will stay shut and (not to confuse things here) valves without pressure will stay shut. The slight pressure from the diaphram spring is the deciding factor. Take the spring out and the valve will not work no matter what.
    Lowering the water pressure in the upper chamber is what opens the valve.
    I think we have beat this topic to death.
    May 2009
    Minnesota
    To jimbo,
    You are right because an activated solenoid retracts.
    Sep 2008
    Virginia
    Quote Originally Posted by PSLawnService View Post
    To rayh 78,
    Yes always leave water turned on going to valves.
    Dont even blow out line. Just use automatic drain valves under each head.
    Not much freezeing here. In winter all I do is unplug transformer, so no power to system.
    DIY Member glnow's Avatar
    Mar 2007
    CA
    As the proud owner my first sprinkler system (inherited from previous home owner), I find this really informative, if I may…
    - How does the manual flow adjustment/shut-off part on these eletric solenoid valves work? Is it OK to use this part of the valve to throttle the flow down a little?
    I lowered the flow on some of mine using this, probably no more than a turn, because in a few a zones water was going too far (i.e. watering the street, my neighbors house, etc). I also noticed that the supply line, which runs in the crawlspace, doesn’t rattle upon shutoff as noticeably as when the stems were fully open (lower flow = less water hammer?). Just want to make sure I'm not hurting the valve, or reducing its lifespan.
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    Keep on adjusting. Turn it down, then back off a bit. Valves will close more reliably, and probably last longer.
