Page 5 of 5 FirstFirst 12345
Results 61 to 74 of 74
Thread: Kohler Rialto K-3402 toilet fill valve repair
  1. #61
    DIY Junior Member jerry k's Avatar
    Dec 2010
    long island, ny
    Jadnashua--
    Thanks for your reply--unforunately they were cut around the bowl. Any other input would be greatly appreciated.
    Jerry K
  2. #62
    DIY Junior Member deana's Avatar
    Oct 2010
    Los Angeles CA
    Default Rialto 3402 redux
    Sorry for not checking back sooner, hj - sorry. Life continues on much the same way: Every few months, the toilet starts hissing and I can see the water in the bowl has tiny waves. I put a little vaseline on the flapper and it is quiet as a mouse for another few months. The same thing happened with a new flapper as with the old one. It would seem to me that this means that the surface where the flapper seals must be uneven. Fortunately, and coincidentally, a Kohler rep told me that my circular overflow valve is too narrow and they now have a rectangular repalcement "flush valve kit" that is free from them. So, I am planning on replacing that and hoping that will fix the problem for a long time.
    I am a little confused about the rim wash issue as someone (below) suggests that a different type of value works fine KWsundell below likes Fluidmaster 400A Fill Valve. You seem to think the 1b1x is the only appropriate repalcement if you want the rim wash. Is that true?
    My conclusion is that, whenever water somehow leaks, it is possible that, if you have modified the rim wash from the original using the 1b1x tube, you will get very noisy siphoning action back and forth leading you to believe that the problem is somewhere else than where the flapper seals. Also, this 1B1X valve seems to have a propensity to spray in random directions and, given the holes Kohler puts in the back of the tank (to hang them to dry after painting, I've been told), this is an accident waiting to happen. I covered those holes on the outside with duct tape and that seems to work.
    I have two more toilets just like this but they work fine, even though the fill valve sprays in random directions on those too, but with the duct tape, it is not an issue.
    Comments solicited. Thanks all.
  3. #63
    DIY Junior Member sam02135's Avatar
    Jul 2011
    Northeast Massachusetts
    Default Rialto .. fill valve/flush valve
    I purchased two Rialto for my rental units. Had an issue with one where the fill valve would not stop and the suggestion from Kohler was to use vasaline, clean the valve etc. Crap (no pun intended)! Kholer is pissing (no pun intended again) me off with their answers: you have to buy a fill valve from us for the Rialto, etc.. BS! The fluidmaster replacement ($10) works perfect! It doesn't cost me $90 for the part which would be 1/3 the cost of the toilet. Kholer acts as if they're Apple Computers.. buy the part from us that you have to.
    As for the flush valve, well . the problem is that these toilets 2005 never flushed that well because it's a rim flushing bowl mechanism. I'm trying to get more water in the tank on the Rialto to get a better flush but their flush valve is unique. Any suggestions for replacement flush valve?
  4. #64
    DIY Junior Member donnjen's Avatar
    Aug 2011
    California
    Partly because of the color, partly because I like to try to DIM, and in order to try to keep it from the landfill, I've been trying to get our Rialto 3402 to work again. Before coming upon your excellent website, I bought and installed, unfortunately, the conversion kit from Kohler (I'd replaced the fill tube with a Fluidmaster years ago without realizing it had no outlet for the rim holes). On flushing, nothing came out the rim holes (I've cleared them out with a paperclip and vinegar and a few do let water out when I pour it through the plastic tubing). I've replaced the water supply from underneath the tank to the wall as well. In the process of checking the tank, the "fill valve diverter/fill valve float" (the black attachment that the rim fill tubing attaches to) snapped off (with hardly a touch!). I"m out $120+ - should I see if Kohler will return my $$$? I see the fill valve diverter is available for under $10 elsewhere so if they don't at least replace that piece I could try taht option. On the other hand, am I throwing good money after bad to keep trying? Since I moved the toilet to a different bathroom than where it was first installed, it only fits up against the back wall. Will that be a problem with the infamous 4 holes on the back of the tank?
    Thanks for any help you can offer on these numerous questions.
  5. #65
    DIY Junior Member KenS999's Avatar
    Dec 2010
    West Dundee, Illinois
    Default Turned Into An Easy Fix
    I replaced the original fill valve in a Kohler Rialto 3402 with a 7 dollar Fluidmaster 400A from Walmart. A suprisingly easy job, as I am definitely not a plumber. I simply trimmed a few inches off the supplied thin black overflow hose and tucked it inside the original large diameter hose that supplies the rim rinse for the bowl. The new flush valve works just fine, and turned out to be an inexpensive and easy repair.
    Ken
  6. #66
    DIY Junior Member DurtyHairy's Avatar
    Oct 2011
    Ramona, CA
    I just replaced a coast 1b1x with the Plumb Pak PB830-13L Item #246711 from Lowes marked as a Coast ballcock 1B1X replacement that is identical to the one pictured in post 45. It was an easy fit and came with the rim supply hose that fit a nipple in the bowl inlet to the rim flush. It works fine. This tank may not even be a Kohler though it looks like one but has no lettering behind the seat and no numbers in the tank. The original slow fill and flushing problems also went away when I opened the angle stop which had probably been half closed to deal with the hissing.
  7. #67
    In the Trades CoastProductsUSA's Avatar
    Aug 2011
    Panama City Beach, FL
    Name:  Screen shot 2011-11-11 at 3.42.21 PM.png
Size:  46.0 KBName:  Screen shot 2011-11-11 at 3.41.59 PM.jpg
    Purchase direct from Coast Products USA, formerly Coast Foundry and Mfg. We have over 112 variations in Flush and Fill Valves, and can build basically anything you like!
    Also ask about our Plumber Direct Pricing, for Industry Professionals.
    http://www.coastproductsonline.com
  8. #68
    DIY Junior Member Asiangem's Avatar
    Sep 2011
    Venice Beach
    Red face
    Quote Originally Posted by jerry k View Post
    Hi folks,
    I have a Kohler Rialto K-3402 PB from the early 1980s and had a plumber in and was told parts are no longer available to completely rebuild of the unit. Does anyone know if this is correct ? If not, can you advise on what parts are needed and where they can be purchased.
    Jerry K
    I have four Kohler Rialto K-3402 PB which were purchased in 1983 for a rental duplex unit. The fill valve was replaced with a Fluidmaster 400 series and works fine on all four Rialtos. I have a round, black flush valve (sorry I can't see the manufacturer name on it) which has a Korky Flapper No 58BP. These are working perfectly fine, with no leaks, no sounds or hisses even with the fact that tenants use them.
  9. #69
    Sep 2011
    Venice Beach
    pwjone1 (Paul Jones) - WOW...thank you for the summary of this thread for the Kohler Rialto Model K3402 - see pwjone1 (Paul Jones) summary of all the suggested parts to use for the K3402 -- took some time to put together since there has been so much written.
  10. #70
    DIY Junior Member wlfhnd66's Avatar
    Dec 2012
    Queens, NY
    I want to thank Ken and other members of this forum for pointing the way. I have a sky blue Kohler Rialto 3402 that was installed in 1987. I had many years of trouble free use but like all things the inside of the tank wore out. I was looking to replace the fill valve that would not stop. I looked for a replacement but I was a little shocked at the price for this item and I was not willing to pay $90 something for it. After I read some of these posts, I bought the Fluidmaster 400A from Walmart for less than $7 and a Fluidmaster universal flapper for $5 to replace the original that had just about disintegrated. I was pleasantly surprised at how easy the Fluidmaster 400A is to install. I just made sure that I read the instructions and understood what had to be done. The only problem now is that the fill valve goes off occasionally for a few seconds but Fluidmaster says that I should make sure the flapper seals drainage opening of the flush valve. I am working on that.
    Gregg
  11. #71
    If the Fluidmaster refill tube is pointing too far down the overflow tube, it will siphon water from the tank, causing constant refills.
  12. #72
    DIY Junior Member steveshrews's Avatar
    Aug 2013
    NJ
    Default Inexpensive and easy K3402 replacement
    I just used the Coast ballcock 1B1X kit from Lowes - in stock at the store. PP830-13L, item # 246711. It cost around $10. I also bought 1 foot of plastic hose with a 1/2 inch ID and 5/8 OD. You'll only need 8 or 9 inches, but 1 foot is the shortest length they will cut.
    This looks different from the original, in that the separate diverter mechanism is not there, both the tank and bowl shutoffs are together in the upper housing controlled by the main float. The bowl is filled from the plastic arm with the 90 degree bend.
    At least in my case the hose going to feed the bowl was too wide to fit the nipple on the bend. There wasn't enough room to use an adapter for the different sizes. Unlike the recommendation in the earlier post (#45 where I got this picture), I was uncomfortable cutting the original hose inside the toilet. That's where the new hose comes in. It fits inside the existing hose and also onto the nipple.
    I put the new hose into the existing one as far as it would go, marked the length removed it and cut off the excess. The right angle bend goes in and out of the main housing easily. I removed it and put it on the new hose, then put the new hose back into the old one. I installed the main valve assembly in the toilet, then put the right angle tube back in. It might be easier to put the tube on first, but this was just the way I did it because I got ahead of myself (I'm an amateur, OK!). The new 1/2 inch tube might have to back out of the old one by an inch or so to fit, but that's OK.
    The first time you flush, the bowl will probably not fill completely. The large screw on the tank fill pipe controls the flow of water. If you tighten it, the tank will fill slower and the valve will stay open for the bowl longer. Just some simple trial and error to get it set correctly so the bowl fills fully.
  13. #73
    DIY Junior Member khinanight's Avatar
    Feb 2011
    Los Angeles
    After all these years....why does everyone still want to keep the Rialto around when there are so many better flushing toilets around? Toto has the round Ultramax MS853113E that uses less water and is more efficient in waste removal. Its taller but If you must have a low-boy then choose the MS863113E.
  14. #74
    Engineer pwjone1's Avatar
    Apr 2009
    Poughkeepsie, NY
    Quote Originally Posted by khinanight View Post
    The simple answer for me is that the Kohler Rialto toilets came in colors, and the colors are very difficult to match with the existing tub, sinks, and tile. So I keep nursing them along until I do a bathroom re-do. Could pretty easily plop in a white toilet, but it wouldn't look right (we have one grey, one pink, one raspberry (sort of a dark red, burgundy-purple). Had a talk with the local Kohler dealer, did not seem we could even custom order one. Lesson learned, from here on in buy white.
    I recently stumbled across this thread again, as I was having trouble with one of the Rialtos that I rebuilt with a Cesco Brass Ballcock:
    http://www.cescobrass.com/Model16ak.cfm
    and a Kohler Flush Valve kit:
    http://www.us.kohler.com/us/catalog/...rtNumber=83650
    The water was running, wasn't shutting off. Poked around, and it appears that the Kohler Flush Valve washer is disintegrating, it's a $3 part:
    http://www.us.kohler.com/us/catalog/...rtNumber=53410
    so I'll probably replace it shortly, but had other projects, so for now tightened down on the screws for the lugs (I could tell there was some problems because one was loose to essentially finger touch), seems to be OK for now. Would have hoped for a little more life out of the Kohler replacement part, but oh well.
    I'm pretty happy with the Cesco Brass ballcock as a replacement for the Kohler part, the diverter valve was a bit tricky so I just stuck with the old Kohler one, and the unit has performed fine, at least so far. It is a bit slower/quieter than the Kohler replacement part (which I have in another of the toilets).
    Paul Jones
