tgreif
I'm replacing a noisy ballcock and I've discovered the hole in the tank for the ballcock is rather deformed. It was manufactured that way. Almost looks like a chunk by the hole was chipped out but the ceramic is fired with that defect. Anyway, the normal rubber donut at the bottom of the ballcock will not seal the hole properly. It looked like the original installer used plumbers putty to seal the penetration but it's been leaking recently.
My question is should I use the plumbers putty again? Or would I be better off to try and reform the opening with plumbers epoxy putty? Or should I just use silicone sealant at the connection? What's the commonly accepted way of doing this these days?
