toolbeltbabe
- Messages
- 3
- Reaction score
- 0
- Points
- 0
I just bought a new home. I've done some electrical work but the dryer outlet scares me. It was supposed to be fixed during post inspection but come to find out they made it "Look" fixed.
Either way, one of the leadwires is a little short coming from the wall, I've tried pulling it out of the wall but there is no give. The first time I noticed this, is when it burned the plastic surround and I saw smoke. I figured out what was causing it and sure enough it was the "short" wire not making a connection so it was getting hot. I've re-connected it a couple of times.
I'm no master but have done a lot of remodeling. Would you recommend I get an electrician or is this something easy to fix?
Can you add to the wire or do I have to redistribute/move the outlet itself to gain more room for proper connection? These are also all Bare wires... is that such a good thing to have?
