Results 1 to 7 of 7
Thread: Garbage Disposal drain/waste pipes
    Default Garbage Disposal drain/waste pipes Pictures Posted
    I need to replace an angle/elbow on my waste line from the garbage disposal out. Problem is that the PVC elbow's at local store are not as long as the galvanized/metal one I'm replacing. With 3 elbows and the trap, there are quite a few interesting turns to get to the actual waste exit. Do these elbow's come in different lengths? What I purchased today at the Depot is not working!
    As a novice do-it-yourself'er, this seemed like an easy repair. Can I take the entire line of pipe from disposal to exit so I can try to match the same angles and turns? And do I just stick a rag in the waste pipe to keep sewer gases out of kitchen?
    Thanks for the help. I've googled every option for replacing kitchen sink drain pipes, but nothing has show quite enough direction.
    Default drain
    It would be interesting to see a picture of your drain setup. It sounds like it was installed more complexly than necessary
    Thanks for the reply! I agree with the more complicated than need be part! Now I have to figure out the female/male end thing! I will win! And learn something new to boot! (with your help of course!)
    And btw, Thanks for the help!
    Here's what it looks like:
    Normally the 90 bend out of the disposer would be pointing down into the p-trap.
    I was looking at turning the disposer so it was to the back, turning the 90 down and fitting to the trap.
    Plumber/Owner Norcal's Avatar
    Mar 2006
    In the Redwoods-Northern Cal
    Quote Originally Posted by Bobbi B
    Yes, it looks like you could swing both the disposal and the p-trap and line them up to make a connection.
    Good luck.
    Plumber plumber1's Avatar
    Aug 2005
    Florida
    You can also push or pull the p-trap in or out of the nipple.
    Don't match all the fittings. Connect as direct to the wall as you can.
    I'd say that it's 50 50 that you can put a new continuous and washer on the outlet of your disposal and not have a leak because of deterioration of the casting at the back of the disposal......You may just need to change the disposal too.
    You should also replace the bad stuff on the other drain.
