Valveman
Multiple check valves are no problem as long as they are both working like new. The problem happens when the bottom check leaks back a little bit, (even a couple of thimbles of water) and the top check is holding perfectly. This is like putting your finger on top of a straw full of water. The water will not drop out of the bottom but it is at a negative pressure between the two checks. Still have positive pressure above the top check. So when the pump starts, the pressure between the two checks changes from negative to positve instantly and you hear a thump. That thump is water hammer and it puts 10 times the normal pressure on you pipe and system. So if your pump delivers 100 PSI (231' of head), when you hear the thump, the pipe leaving the pump sees a 1000 PSI pressure for an instant. In a water well situation the pipe and pump actually try to jump out of the well when this happens. If you only have a check at the bottom, the pipe is always under positive pressure when the pump starts and no water hammer.
