Tickridgescott
I will be installing my submersible goulds pump in my cistern this weekend. I will finally have running water after 2 years. I am building this summer and need water - especially for when we do the stucco work in a few weeks. I have ran off a 5500 watt honda powered coleman generator this summer during the building process as I will not have access to electricity for a few more months. IIs it fine to run the submersible pump off the generator? The generator has a 230 volt power supply with a special plug on it (that i plan on using to power my 230 volt pump).
Also this is an additional question- is the pressure switch for turning on and off the pump simply wired in series with one of the legs of the 230 volts for the pump?
thanks,
Scott
thanks,
Scott
