Thread: How do I fix a leaky faucet?
    Question How do I fix a leaky faucet?
    I haxe an Artistic Brass single handle bathtub / shower faucet. It is either a ceramic disk or a ball joint. It is leaking hot water. The problem is that I cannot get it apart to fix. I have removed all of the allen wrench screws holding the handle on, but the handle will not come off. I am afraid that I will break something creating even more problems.
    Plumber Plumber2000's Avatar
    Jan 2005
    Eugene, Oregon
    If you can't take it apart without something breaking on it, then maybe time for a new faucet.
    Plumber for 20+years
    Default Leaky faucet
    Hmn, it might be time for a new faucet, but I suggest that you try to fix it yourself before you have to resort to buying a new one. I went to this site to figure out how to fix my leaking shower head:
    http://gabwith.us/diy-and-home-impro...pping-faucets/
    And I realized that it was the washer that needed to be replaced. But if you are having problems unscrewing the entire thing, then may call a plumber? It's either that, or your risk breaking something, and then you're back to plan A. recommended by Plumber2000 and buying a new faucet.
    Charlote
    Default Ab
    If the handle was held by setscrews it pulls off once they are removed. If it doesn't it is stuck and has to be tapped off since you cannot use a handle puller. Artistic Brass did not make their own faucet valves. They used Price Pfister or some other common brand, depending on the age of the faucet.
