Results 1 to 2 of 2
Thread: sand in water
    Default sand in water
    About a year ago we replace our well pump with a more powerful pump. At the same time a larger pressure tank was installed. The purpose of which was to increase flow because we had added an irrigation system.
    Now the problem... I have a "big blue" filter that I have been replacing every 2 weeks since we made this upgrade..it is caked with sand. Prior to the upgrade, I was replacing the filter every 3 months (little or no sand). We've had the well "re-developed", but the sand still exists... HELP
    Moderator valveman's Avatar
    Mar 2006
    Default Valveman
    Sand comes from the well because the well screen and/or the gravel pac is not right. Bigger pump, more water, more sand. Pumps cannot take this kind of sand very long before they are destroyed. You can add a bigger filter or a sand trap but the pump is still being destroyed. My rule of thumb has always been, if the pump will last atleast 5 years, you can afford to filter the sand. If the pump does not last 5 years, it will pay to get a new well. I would guess your pump will not last 5 years. In our area we guarantee sand free wells. We use small screen or perf casing and very small gravel pac for filtering the water as it enters the well. This is the best place to filter because your pump never has to pump the sand. "Redeveloping" probably means the well was bailed out a little. Don't think there is anything they can do to the well screen unless you have big enough casing to run a liner with a new screen. ie; 6" casing with 4" liner and screen. Sounds like you need a well driller. Just as well fix the problem as anything else is a non stick band aid. Might be a hole in the drop pipe or excessive cycling, but you should have noticed other problems if that were the case.
