djarp
- Messages
- 13
- Reaction score
- 0
- Points
- 0
I just installed a 1/2hp flowtec jet pump, but when I use more than one faucet the flow goes down the hot water heater is tankless and the unit shuts down when the water flow changes. The tank is 82gal and is set to 38lbs the pressure switch is set to 40/60 the well is 30ft deep and 10 ft from the house. the gauge reads 38 when switch is on and 60 when off. Is the pump too small to handle the volume of water use in the home.
