Thread: septic
    Default septic
    Back already. I have another question. I have a septic tank and a cess pool. There is a pump somewhere to move the water from the tank to the pool. Where would this pump be? I have an earth contact home, consequently no basement. Thanks
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    Quote Originally Posted by dickie5
    You have a septic tank AND a cess pool? That's interesting. Could it be inside the septic tank? I'm assuming you have a breaker in your breaker panel for it? Can you follow those wires to the pump?
    Jason
    vaplumber
    Guest
    Septic tank and cesspool together are a possibility. Septic tank is not used as a septic tank, but as a pumping chamber to pump uphill to the cesspool. The pump is in the septic tank, and if you have the tank emptied, you will see the pump. Another possibility is that you may have a septic tank with a leeching pit, which may resemble a cesspool, but is not. In that case, you will have a pumping chamber, (a smaller tank) between your septic tank and your leeching pit, which pumps the grey water up hill to the leeching pit. Your pump will be located in this chamber. Pumps are only used where the waste has to be pumped up hill, or over a great distance, except in case of some of the newer alternative systems which use pumps and airators.
