Results 1 to 2 of 2
Thread: Oatey Shower Drain Install
Hybrid View
    Default Oatey Shower Drain Install
    I am trying to install an Oatey Shower Drain. The drain comes with two washers a fiber washer and a rubber washer. The question I have is how to install this drain in a fiberglass shower stall base. Which order do they go in and should I use plumbers putty at any time during the install? Does the rubber gasket go between the drain base and the shower base and the fiber gasket on top of the shower base and under the screw in drain top? Help...
    Plumber, Contractor, Attorney LonnythePlumber's Avatar
    Wichita, Kansas
    Cool Silicone
    Put silicone under the strainer flange and insert strainer into inside hole in the shower base.
    From bottom install the rubber washer against the shower base, the cardboard friction washer next and then the nut. These nuts tend to come loose and are usually not accessible after installation. It's better to use a brass strainer. If not use pipe sealant on the threads and get it tight.
  1. Getting strainer off Oatey shower drain
    By Rutherfordman in forum Shower & bathtub Forum & Blog
    Last Post: 06-02-2010, 06:51 AM
  2. Oatey Casper Shower Drain Kit
    By RD1102 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-15-2009, 08:56 AM
  3. replacing Oatey shower drain
    By richardguy in forum Shower & bathtub Forum & Blog
    Last Post: 07-24-2007, 06:01 PM
  4. Oatey Casper's shower drain
    By bellyjelly40 in forum Shower & bathtub Forum & Blog
    Last Post: 03-11-2007, 07:48 PM
  5. Oatey shower drain question
    By jrseaberg in forum Plumbing Forum Discussion & Blog
    Last Post: 03-03-2007, 02:45 PM
