I have 800 feet of 1" 80 psi poly feeding a couple of faucets at the back of my tree farm. I can run one sprinkler very well with it. I haven't tried to use more than this at any one time, but if you want, you can check the friction charts for plastic pipe at any given flow rate and see how much loss there will be.
Just be sure to run the right size for the amount of water you plan to use, or you will be sadly disappointed.
bob...
