In order to make a very strange but neccessary PVC drain trap arrangement work I must somehow glue an 1 -1/2" PVC male threaded adapter into
the female end of a regular 1-1/2" PVC T fitting (meantfor glueing with PVC cement). Its a fairly close fit(though obviously not intended for this ). If I fill it with epoxy so it oozes out when the two are joined, will this permanently seal the joint? I need an epoxy that will bond this together permanently and never leak. If I can achieve this it will save me a WHOLE lot of work.
The reason I must do this is because the old PVC trap parts are from a
company that went out of business and new stuff won't thread on. Getting rid of the old is a big job because it is barely accessible and glued on. So I must add on
with a new T which must be epoxy'd on.
Can I count on this staying sealed and what's the best product to use that will bond to PVC and hold up over time for wide joints.
Thanks for your help.
JH
JH
