Results 1 to 5 of 5
Thread: Garbage Disposal and Dishwasher problem
    Default Garbage Disposal and Dishwasher problem
    Small problem and I can't quite figure out what the problem is. I had to replace my garbage disposal. Got a new one, replaced it. Hooked up all the old lines into their proper places and away we go.
    The only problem is now when I run by dishwasher, instead of draining completely through the drain line, a fair amount of water comes out of the over flow line next to the faucet.
    The garbage disposal works fine. I have stuck a snake down the pipe with no apparent problem. I have reconnected everything and checked all the connections. There are no leaks from the garbage disposal itself. All the pipes are tight.
    I can't figure out where the problem is. It is only when I run the dishwasher that water comes out of the overflow next to the faucet. Any help would be appreciated.
    DIY Senior Member Jeff1's Avatar
    May 2006
    So Cal
    Did you remove the plug from the disposal where the dishwasher connects to it?
    Tradesman Plumber Kristi's Avatar
    Jan 2005
    Vancouver, BC
    you need to bang out the plug inside the drain port of the garburator, which is what Jeff said. Imagine if you wanted a garburator, but not a dishwasher - this is how you could accomodate everyone! I would remove the garburator, lay it on its back with the drain port facing up, take my big utility flathead and give it two good whacks with a hammer... keeping in mind that this is an appliance, don't be too rough with it.
    ~k~
    Default Thanks
    Thanks. That was the trick. Didn't even know that was a problem.
    Christopher
    Yakima WA
    Too bad every problem isn't this easy to diagnose!
