Brass Shower Drain
PEW
DIY Senior Member
Brass Shower Drain rubber seal ?
In the attached photo you will see where the screw-in ring has forced the rubber seal inwards. Is this the way it should look? There was a beveled end to the rubber seal which I placed downwards as it seemed to match the shape of the brass housing (there were no directions as to which way it should go).
Any comments?
Paul
I believe that the screw-in ring has a taper to it that will match the taper on the rubber sleeve.
I've been putting the taper "up".
I run the pipe a little higher too.
