Results 1 to 2 of 2
Thread: Brass Shower Drain
    Default Brass Shower Drain rubber seal ?
    In the attached photo you will see where the screw-in ring has forced the rubber seal inwards. Is this the way it should look? There was a beveled end to the rubber seal which I placed downwards as it seemed to match the shape of the brass housing (there were no directions as to which way it should go).
    Any comments?
    Paul
    I believe that the screw-in ring has a taper to it that will match the taper on the rubber sleeve.
    I've been putting the taper "up".
    I run the pipe a little higher too.
