Thread: 110v or 220v??
    Exclamation 110v or 220v??
    old submersible was pulled and replaced both were 220v.?? is old pump was taken apart and fixed for a portable pump ie to pump water from a pond to a pool i think it might have been wired 110v. how do check the voltage needed to run this pump???
    Plumber Cass's Avatar
    There should be a tag on the side that gives HP,voltage, amps, ect.
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    "old submersible was pulled and replaced both were 220v.?? is old pump was taken apart and fixed for a portable pump ie to pump water from a pond to a pool i think it might have been wired 110v. how do check the voltage needed to run this pump???"
    If I understand your question properly, a 220 V well pump was adapted to be used as a portable pump.
    I have never seen a submersible well pump that could be rewired for a different voltage than it was built for. If it was a 220 V motor, it is probably still still a 220 Volt motor.
    If it is a submersible well pump motor, the information is probably etched on the side.
    Exclamation 110 or 220 volt
    thanks fellows found stamping and its is 220v thanks again
