Results 1 to 3 of 3
Thread: Tub to Shower conversion to save space
    Default Tub to Shower conversion to save space
    I have a 32" wide tub on concrete slab with drain mounted about 6" or so from the wall. I would like to convert to a 32" square shower, but the pans I have seen all have the drain about 16" from the wall. Does anyone make a 32" pan with the drain 6" from the wall, or is there something I don't know about tub/shower drains? I know Swan makes a tub-shower conversion floor pan, but it is 32" x 60", which is too much space in my micro bathroom/studio condo. Thanks for any help from anyone who has done this.
    The problem is that when you put in the shower pan (floor), it needs to slope 1/4" per foot. In order to look good, you need the same drop from each wall to the drain. That means you need about 9/16" in 6" on the short side. If the drain was in the middle of the 32" (and that is a small shower!), then you'd only need about 5/16ths drop from each wall to the drain.
    You really should consider moving the drain to the middle of the shower, then you'd have a bunch of options. If you want help with tiling, consider going over to johnbridge.com probably the best tiling site on the web. They have a bunch of good people (and are friends of Terry's), plus a good library where you can do some research.
    Thanks much for the help. My mom suggested that I pour my own shower pan, which might not be too bad an idea. Thanks for the drainage info.
    Dean
  1. Shower to tub conversion?
    By ralleman in forum Shower & bathtub Forum & Blog
    Last Post: 02-18-2013, 07:46 PM
  2. 1929 bath/shower controls - save them?
    By machina in forum Shower & bathtub Forum & Blog
    Last Post: 01-26-2010, 07:04 AM
  3. Save my new shower!
    By ShannonT in forum Shower & bathtub Forum & Blog
    Last Post: 01-16-2009, 06:50 AM
  4. Tub shower conversion help
    By kpaisley1 in forum Shower & bathtub Forum & Blog
    Last Post: 07-30-2005, 02:33 PM
  5. Tub to shower conversion
    By onestopguy in forum Shower & bathtub Forum & Blog
    Last Post: 12-06-2004, 11:05 AM
