Dunbar Plumbing
I've been putting these valves in for years and I am curious if any plumbers notice this when installing them.
Whether you use the plastic shroud or not when installing the valve, no matter if it is a thick wall or thin, when you tighten the screws either evenly or alter back and forth the valve never tightens down perpendicular to the wall you mounted the faucet on.
Not once have I ever had a complaint of this situation but I'm a perfectionist when putting the final touches on any item I touch in plumbing. I've tried numerous ways to get the valve to straighten out but I really think that the way the screws are set at the 2 and 7 o'clock positions is what is causing the proper straight alignment. Like I stated above, I've been installing these for years and with or without the shroud, they all angle to some degree. I put in 2 just this past week with each one having totally different circumstances and neither one I could get to straighten out on the final tightening of the valve.
