Thread: Ducting exhaust fans in bathroom remodel
    Default Ducting exhaust fans in bathroom remodel
    We are remodeling 2 bathrooms which are just separated by a wall. We are installing an exhaust fan in each room and are wondering if the ducting for each could be joined and share one outside vent?
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    This is allowed, but make sure both units have the little one way flapper (check valve) in place. Wouldn't want to exhaust odorous air into the next room.
    If noise level is a concern, I wonder if the duct will carry sound between the rooms.
    I'm not sure if they make a wye fitting for the duct, a tee is available though.
    Jason
    Smile
    Thanks for your help.
    DIY Senior Member finnegan's Avatar
    Aug 2005
    CT
    You might want to check out the inline vents that are designed to be mounted remotely and service mulitple bathrooms.
